VegaObscura
- Jun 19, 2010
I have a 92 grand am that was sitting in a field for about 8 years before I got it. Surprisingly after replacing just the battery, a couple of hoses, and a couple of fuses most of its parts work. It doesn't show leaks of any kind, it turns over, and when I spray starting fluid into the intake, it starts up but only for as long as the fluid is being sprayed. Unfortunately the gas hand reads almost full. Now I'm faced with the problem of getting about 15 gallons of 8 year old gas out of the tank so I can put fresh gas in. I first tried to siphon it, but I can't get a hose all the way in the tank, and that wouldn't get rid of all of it anyway. Next I looked for a drain bolt under the tank, which it doesn't seem to have. Then I tried taking the gas line loose at the fuel filter, and that got me a few drops out but no more. I tried turning the switch on, and even tried cranking it and pumping the gas pedal while the gas line was disconnected from the fuel filter with a drain pan under it, which didn't seem to do anything. I then reconnected the fuel line, tried turning it over again, then disconnected the fuel line again and a little gas sprayed out, so I know its getting pressure and the fuel pump is working at least while the fuel line is connected. I wanted to try bridging the relay so the fuel pump would run continuously, but I don't know where the relay is located and I've been googling for days trying to find its location but nobody seems to know about 92 grand ams. So if anyone knows where the fuel pump relay is located, or another way to get the gas out, please let me know.
I hope that wasn't too long. I like to give as much detail as possible.
