Grand Prix SE 3.1 V6 temp reading issues
Recently my 93 grand prix is having issues with its temperature reading as well. I replaced the temp sensor, the temp sending unit, and I needed to replace my low coolant sensor (that has been bad). I also replace my thermostat as well. The temp goes to redline and above, then drops to 280 or so, if I run the heat, it will drop to normal operating levels for a while. Is this a water pump issue? My fans do turn on. Could it be a relay for my fans (not turning on soon enough)? I released the pressure valve looking thing on top of the thermostat housing to see it any water was flowing. All I got was a hissing noise with no steam and no stream of water. Any help on this would be appreciated.
