hello everyone, its my first time here/posting. so take it easy on me,lol
ok just got a 95 grand prix with the 3.1 v6, but it has problems, it does run i been driving it uhm alot of times its hard to start, always starts but turns over longer than it should, and when i push gas padel hard it boggs out and is way under powered while driving, (no-power) but if i drive like an old lady on a sunday drive it seems to be decent/drivable. but not always!!!!! idles ok then sometimes it idles like crap
any ideas??? i was thinking egr related, i took it off to inspect and the passage from egr to intake/(in the actual intake) was plugged bad, i had to chisel it open it was rock hard,, anyway it never seemed to help that much, a little though. i just cleaned not tested. so it could be egr?
im sure someone here has had or seen this issue (hopefully)
Injector/s ?
Fuel press. reg ?
Plugged cat. converter ?
Mass Air Flow (MAF) ?
Throttle Position Sensor (TPS) ?
Idle Air Control (IAC) ?
Vacuum leak ?
Or ?
Injector/s ?
Fuel press. reg ?
Vacuum leak ?
Or ?
