I've had my 96 Grand AM since the late 90's and have had few problems out of it. Though recently after relocating it ended up sitting for 2 years and haven't really touched it since then.
The other day I decided to get it back on the road and after replacing a battery (which is needed) I tried starting it up but it was as if there wasn't any fuel in the gas tank, it was turning over like it was trying to start, just wouldn't catch. The gas tank is at least 2/3 full. Now this could be part of the problem, but that fuel has sat in it since I parked it, so the fuel is a bit old.
I also sprayed a little gas in the mass air valve while I was trying to get it to start, and it would sound like its starting but then cut right out. So I was thinking it could be the fuel pump or the fuel filter. I haven't changed the fuel filter since I've owned it nor the fuel pump.
I was just wondering if anyone here had any ideas or has had similar problems or possible solutions.
Thank you.
Thank you.
