Try turning the key to the run postion w/o starting the car. Shift to nuetral and then start the car and shift to drive. Have someone check the switch that mounts above the brake pedal.
Most likely you have either a bad brake switch, it is mis adjusted, or the brake shifter solenoid is bad. You can bypass the brake switch or remove the solenoid all together, but that is where you need to start.
there is a "U Clip" right under the release lever on the handle of the shifter..sometimes they break..if it is broke ,then that would be your problem..
