96 GT - Tail lights, dash lights and lights on buzzer quit working
TxSunfire96
I have a 96 gt that suddenly lost it's tail lights, dash lights and the lights on indicator buzzer all at the same time.
Brake lights, blinkers, head lights all still work.
I did a quick search for "tail light" and for "dash light" and multiple combination of both. But came up empty handed.
I have checked the fuses and tail light bulbs before I noticed the dash light and buzzer quit as well and everything appears to be correct.
Where should I head from here?
Update: I forgot to mention that the buzzer still works if the key is in the ignition and I open the door. So it appears to be solely related to the things controlled by the rotating light control on the blinker lever.
Is there a control board that related to this one part? Is it all operated off of a single fuse?
do you have the owners manual which lists the fuses to check?
No, I got the car from my brother in law and he did not have the manual for it. I have searched for a '96 pdf manual with no luck so far. I can find 99 and up manuals but none for anything prior to 99. I also checked all the local sources for a Chilton's style manual for this model and there are none local, I guess that is the price of living the country life.
I checked the (edit) dash fuses themselves with a voltmeter to make sure that current would flow thru them and found none bad that way in my initial testing.
These are the descriptors in the manual for the 99 model:
Dash Fuses:
TURN-B/L Exterior Lamps, Back-Up Lamps
F/P-INJ Fuel Pump, Fuel Injectors
RR DFOG Rear Window Defogger
CLUSTER Instrument Cluster, Anti-Lock Brake System
CLS/PCM Instrument Cluster, Powertrain, Control Module, Daytime Running Lamps
O2 HTR Rear O2 Sensor Heater
WIPER Windshield Wipers, Windshield Washers
ERLS Automatic Transaxle, Brake-Transaxle Shift Interlock (BTSI), A/C Compressor, Cruise Control, Multiport Fuel Injection
AIR BAG Supplemental Inflatable Restraint (SIR) System
PWR ACC Power Door Locks, Convertible Top
EXT LAMP Exterior Lamps, Instrument Panel Lights
HVAC Heater and A/C Control, Engine Cooling Fan
RADIO Radio, Remote Keyless Entry
ALARM Alarm Module - Interior Lamps, Warning Chimes
CRUISE Cruise Control
STOP HAZ Exterior Lamps, Anti-Lock Brake System, Cruise Control, Turn Signals
CIG Cigarette Lighter
INST LPS Instrument Panel Lights, Warning Chimes
PCM/IGN Powertrain Control Module
L HDLP Left Headlamp
INT LAMP Alarm Module: Illuminated Entry, Warning Chimes, Overhead Lamps, Map/Reading Lamps, Glove Box Lamp, Trunk Lamp, Radio, Power Mirrors, Remote Keyless Entry
IGN Engine Ignition
R HDLP Right Headlamp,
HORN Horn, Diagnostic Connector
PWR WDO/SRF Power Windows, Power Sunroof, Convertible Top Controls
DRL Daytime Running Lamps (Relay)
Under Hood Fuses:
IGN Ignition Switch Circuits
BATT 1 Power ACC/Stoplamp Circuits
BATT 2 Lighting Circuits
ABS Anti-Lock Brake System
COOLING FAN Engine Cooling Fan
BLO Heater and A/C Blower
PCM Powertrain Control Module
A/C A/C Compressor
ABS/EVO Anti-Lock Brake System
Now I have not checked the batt2 fuse under the hood, but I will do that shortly.
Took the voltmeter to the fuse box and found one of the 20a fuses wasn't getting juice at the box... fixed.
Thread can be closed\deleted, thanks.
