Q
quick_5_up
96 Pontiac Sunfire pistons #2 an #4 misfiring. I took it to my friend that has a computer. He hook it up an took it for a drive an piston 4 was missing like crazy wile piston 2 missed a couple of times. i change out my spark plugs and coil boots (wires) did a oil change. also he checked my EGR valve an discovered it was clogged with black soot. so we unclogged it an now after a month its clogged again and the black soot looked worse. Now a new code has come up to say o2 sensor after the catalytic converter is bad could that be the problem cuzing all the soot if not what is ? could it be the pistons misfiring if so why could they be misfiring?
will gutting the cat or replacing it fix the misfiring?
