Instructions
1.Lift the vehicle hood and support it with the hood prop rod. Allow the engine to cool completely before proceeding.
2.Turn the coolant pressure cap a quarter turn, and wait for the hissing noise to dissipate. Remove the coolant pressure cap.
3.Locate the air bleeder valve on the heater return hose on the left side of the engine.
Some people recommend turning your temp control knob to full hot.
4.Turn the air bleeder valve counterclockwise with the line wrench. Slowly pour fresh DEXCOOL coolant into the neck for the coolant pressure cap. When a steady stream of coolant pours from the bleeder valve. Close bleeder valve.
5.Top off the cooling system to the "Full" mark with the fresh DEXCOOL coolant. Install the coolant tank cap.
This is the correct way, but not the way I did it. I installed a flush kit, and filled the system as much as it would take. I then ran the engine at idle with the cap off and the flush cap off also. When I saw that there were no more bubbles generated in the coolant tank I shut the engine off and put the caps on. This can be dangerous as it can spray boiling coolant out of the coolant tank. I was desperate and performed the procedure with another trained mechanic. My bleeder was broken. See pics below.
Pic of original bleeder. It is located on the metal pipe in the center of the pic. Older models may have another bleeder on the thermostat housing.
Pics of flush kit.
