Hello all, I am helping a friend with an overheating and fan not functioning issue. We replaced a faulty stuck thermostat, then within minutes of that fix the water pump went so we replaced that, the fan does not turn on when it is suppose to. We have tested the fan directly (working) tested the fuse (working) tested the relay (working) un-plugged the ECT sensor (fan turns on), jumpered ECT (fan turns on), tested the ECT sensor, (readings where all over the map so replaced it) But the fan still does not come on when it gets hot.
I have read that the 2.2l has two coolant sensors but there is not a sensor anywhere near the pulleys. Can anyone tell me what we should try/test next, or if you have a link handy to a similar situation can you post it please?
