My 97 Sunfire has lost power and doesn't want to shift properly. I got a diagnostic report that it has an oxi sensor mishap so I changed the front at manifold with no improvement then the rear sensor after the converter and the check engine lite went off but test drove to find it still has weak power and doesn't want to auto shift at proper speads? I changed both the crank possision sensor and cam possision sensor and the cat converter along with checking spark to all 4 plugs which are also clean and gapped properly. Air filter is new and plug wires are fine. all coil packs are fine also. I haven't found any vacuum leaks and don't know what to think at this point??
