I've swapped out the EGR,MAP sensor,crank possision and cam possision sensors,ignition module,and swapped the plug wire around while keeping it in fire order but it still has a weaker spark on the #1 and #2 plug. I tried switching #1 wire from coil pack to #4 plug and #4 to #1 and the weak spark switches to #4. Is there anyway to test/check the coil packs? It just doesn't make sense that the #1 and #2 on both coil packs would be weaker? The coil packs are #1 and 4 on one and #2 and 3 on the other. Is it possible the this could be a timing chain? I'm getting rapid misfire codes on all cylinders?
