S
skippy
...floor.? Ok so i replaced my front brake pads on my 98 trans am. I did not undo the brake lines. Using a c-clap & and an old brake pad, I slowly pushed both pistons back into the caliper. I did that for both sides. With the engine off the brake peddle gets hard to push in after a couple of pushes. However with the engine running, I can easily push the peddle down the to the floor if I choose to do so. Is this what happens when the ABS get out of sinc? How do I resolve this issue? This was my first time out so the more detail you can give me the better. I have a feeling I’ll need to bleed the brakes. If so any pointers on that would be helpful as well.
Thanks.
Thanks.
