Katsr86
So I got a 99 pontiac grand am se from my mother. it had brake problems and needed two new hubs and some engine work. I took care of the engine work. I replaced the two front hubs abs and trac off lights went off. Discovered the two front calipers seized onto the rotor when pressed. heating the rims of the tires. So I replaced the calipers. Bled them figured why not replace the back shoes. took them off turned the self adjusters so that there was enough room to fit the new shoes in the drums. bled the rear.
went to put the car on ramps in the rear tires in reverse.............. blew rear brake line to passengers side rear. Went over ramps....... Everyone thot it was funny had a few good laughs. landed perfectly on jacking point so nothing got broken or damaged. So I replaced the rear brake line. Bled the rear brakes again. Brakes work real good when the car is off. I turned it on and the pedal goes to the floor. So I figure air somewhere in the lines. So I bled them all 3 more times. didnt work. So I bought some clear rubber hose tubeing. Slipped it over the bleeders and the other end in brake fluid. got all the air bubbles out one at a time swapped out all the old fluid. Still no results. Did I do something wrong???? Or am I looking at a new master brake cyl ??? PLEASE HELP. The brakes do work whil drive just at the very bottom of the pedal. There perfect when the car is not on. Thank you
