I searched the forums but couldn't find the exact problem.
It is; radiator fan will not run even when AC is turned on which when that happens eventually kicks off comp due to high side pressure.
What's been done; replaced coolant sending unit & harness (temp gauge was not working, works now), replaced thermostat, disconnected fan & hooked direct to battery for a sec to see if it ran (it did), swapped heater & coolant fan relay to check relay (blower fan still ran), checked 30A fuse (good), checked for power @ fan connection (no voltage detected), any ideas?
