ericv1984
About a week or so ago the ABS light was on, noticed that it didn't have a fuse under the hood so I put one in. Then today we had to take the wheels off to install new hubs and bearing and camshaft position sensor, now the ABS light on the dash is on again. I checked the fuse to make sure it wasn't blown and the fuse is fine. There is another bigger 40 amp fuse that I can't see if it's blown or not cause I cant pull it out (it's stuck), and the ABS relay which I don't know how to tell if the relay is bad or not.
I also read that the ABS light being on could also mean the wheel speed sensors. So I was wondering if anyone has any idea on what it could be?
