pretty much the same as for any rusty bolt, a combination of shock from a hammer blow, heat, and liquid rust penetrant. For the penetrant let it soak overnight perhaps using a cloth around the nut to keep it moist. Make sure you use a 5 sided wrench to not round the nuts. You can try heating it with a propane torch, let it cool off, hit it a very times, and then apply the penetrant.
