Where is the fuse for the air conditioner on a 1996 Grand Am? I'm not even sure that's what my problem is, but I want to at least check it. I think the car might have a slow freon leak, but I put a gauge on the low pressure side and it is up to the correct pressure but the compressor won't kick on. The fuse is the only thing I can think of to check. I may try by-passing the compressor relay to see if the compressor will at least kick on. Is there reset switch or something that might be the problem? I would appreciate any ideas.
Thanks...
Thanks...
