Will always crank, but intermittenly won't start.Towed to dealer, they said needs new fuel pump, replaced pump worked fine for days then trouble back again. Fuel pressure at rail always good, replaced fuel filter, always has spark. Will run when gas put in throttle body till gas is gone. No codes when dead or running. Does this in all weather conditions. Might not start for days, being checked 4 times each day. Then will run for days. Other than 200,000 miles on her pretty reliable. Bought new camshaft sensor and crankshaft (7x) goes in side of block, hoping someone else can help before replacing then cause this car is not easy to work on.Thank you for any and all help/advice !
