Dr. Sievers
I want to start by apologizing, Goatman, this is not a pontiac vehicle, I just don't belong to a honda forum because well... If this wasn't my wife's car I wouldn't own it.
I have a 2004 Honda civic LX 1.7L I4. Okay the problem is the othe day I had replaced the 4 grommets and the gasket for the valve cover. Well the grommets are just fine no issues there, but, the gasket is leaking out of the belt drive side.
I checked to make sure that the gasket was lined in properly and I made sure to torque the bolts back down to 7 pounds of pressure just like the book said to. Well at first I thought that it could be just the book is wrong and it needs more pressure because seven pounds of pressure just doesn't seem like enough. So I tried to drop it to about nine and a half. I didn't want to go over board, and it still is leaking. Do you guys think it could be just a bad gasket or is there anything else I could have done wrong: Below is my exact process.
1) First removed the "engine cover" (a samll 12"x6" piece of plastic)
2) pulled the coils and removed the wire bar from on top of the valve cover
3) cleared some space in the compartment to make work easier.
4) pulled the valve cover off (got to use a shorty flat head to pop it out of place
5) used a grommet pryer to pull the grommets and used my fingers to pull the old gasket
6) replaced grommets and gasket
7) slid valve cover back into place
8) tightened bolts to 7 pound of pressure
9) put everything back where I found it
2 days later
1) repeated 1-3
2) tightend bolts down to 9 pounds of pressure
3) replaced everything
2 days later
Oil is still leaking and I have a replacement gasket coming because... well duh.
Just want to see if I missed a step maybe.
2 days later
1) repeated 1-3
2 days later
