Hello all,
I had a bunked radiator that was spewing, so I took a trip down to the pick-ur-part and pulled one from a 2004 (I have a 2001). They are identical. When I pulled the one from the yard, I just unscrewed the automatic transmission cooler lines instead of pulling the little pin and undoing the quick disconnects.
I put it into the van, and the connections leak. They are leaking from inside the quick disconnect as best as I can tell. Keep in mind that I'm using the connections / bolts from my original van, so the sizing should be exactly the same. I've removed and reseated the connecting bolts to ensure that the the cooler is seated correctly, and I'm pretty sure that the fluid is coming from the hose side of the connection rather than the bolt/radiator side.
Anybody have any ideas as to what I did wrong or what I can do to fix it?
Also, I've *TEMPORARILY* bypassed the cooler with a bit of hosing. How long can I run the van until the trans kills itself? It's winter, so the ambient temperature is low-ish (in the 40s and 50s around here).
thanks,
-Jason
thanks,
-Jason
