I have a 2002 Pontiac aztek which has been converted to a 2WD from AWD. The vehicle works great but the AWD light on the DIC stays on. Is there any way to eliminate this?
You would need a wiring diagram to determine if there is a sensor that is causing this and then somehow fool the sensor into thinking the AWD is functioning. I take it you are not interested in getting the AWD properly repaired?
