tokashikibob
- Jan 31, 2016
Hi, I have a big problem, it looks like the Fuel pump fuse is not making connect with the pins in the fuse box. I went ahead to the junk yard and got another box and plugged it in however the car wound not crank.
Put the old one back in and the car would crank but still no power down by the body plug under the chassis.
You can see inside the fuse holder that the pins are pushed back and the fuse does not have any friction going in and out.
1. Does the Aztek have anti theft with the fuse boxes since the junkyard one wouldn't crank
2. Have anyone repaired the internals? It looks like they did not make the fuse box able to come apart. I tried cutting on the junk yard part to no avail.
Any help would be welcome!
Best regards,
Bob
Best regards,
Bob
