thundercat
Member
- Mar 6, 2015
My car is a Montana 2003. While engine temperature no reach normal level the driving is normal (idle > 700 rpm). But when temperature its about the normal, instead idle still at the usual 600 rpm the needle of revolutions fluctuates like if any time engine go turn off (usually happen when I driving and can't stop until reach my destiny), some minutes later idle revolutions ups more than 1500 rpm (without push the accelerator pedal), by sporadic appear 3 warnings (ABS, Service Traction System and air bag) for few seconds but they disappear when not touch the accelerator pedal (an electric issue?)
Never overheating, brakes works ok, codes are PO171 and PO300. I changed the IAC valve and the TPS sensor, but that doesn't fix. What could be happening? Thanks
