Hi Fellas!
Okay, I am having the new battery drain down over a few days of sitting.
The Alternator is charging when its running and I disconnected the plug and hot wire from the alternator and my test light between the neg post and cable did not change.
Had helper hold test light as I removed the fuses one at a time. The only fuse that made a difference was one labeled courtesy. The test light went dim with it removed.
I think that is correct as the minimum draw is something like .25 milliamps due to the radio/ecm ect. Does the courtesy fuse run the dash lamps? can I run the car without it? Anyone have a similar problem?
We are getting aggravated! Yes we are! (Matrix2)
