Stupidgirl
 - Oct 17, 2021
Changed both bulbs blinker works but both lights won't come on can anyone tell me what the problem is
In a previous post you had a Grand Prix, this is the Solstice forum. What car is having the issue?Since I know this thread is being looked at...
I am having the same problem, in the rear, where there is only one bulb. Changed it with the correct bulb (3157). Changed the socket. Now, changed the turn signal lever. Still, no brake light or right turn signal. Help!
At any point while changing all these parts have you used a voltmeter or ohmmeter?The Solstice.
I might, if I knew how.At any point while changing all these parts have you used a voltmeter or ohmmeter?
