The water nipple on the back of the block is rusting out. Any advice on how to remove the nipple.
Also, where is a good place to buy a replacement. When I put the new one in do I need to use sealer of some type?
I think he is referring to the heater hose nipple that is actually located on the passenger side head of a V8.
Removal and installation is the same as freeze plug, just use a socket that goes around the hose connection. be sure to clean out the hole before trying to install the new one.
