Lokim
Can I put the turbo cam in my non-turbo 1.8L 86 Sunbird without throwing codes/having driveability issues? I appreciate any input.
Thanks!
Thanks!
I don't think I'll need the turbo computer because the compression won't change due to boost, I'll just have a bit more oomph (hopefully.) I'm thinking that since the mixture will be monitored via the MAP and O2 sensors, it shouldn't throw any codes because everything will be accounted for.
Did you get a CEL when you swapped in the cam on your S-10?
Also, when you say it helped "some," what do you mean? Did it have a little more pep off the line? Did it climb hills a bit better? Would you say the gain was 5hp or 15? More?
