Can I get replacement keys for my 1987 Pontiac
  • Thread starter Thread starter William G
no. if they're locked in, break the window. if they're broken in teh ignition, call a locksmith.
Incorrect.
You can easily get new keys made by about any locksmith by the pin-set in the door lock. This is easy enough to remove with the right tools, or have them remove and re-install. This is the only way you're going to get new keys made for that pin-set. Pontiac will not issue you new keys based on the VIN.
Call a locksmith, they can help you out.
if you completely lost the keys then you can probably contact pontiac with the vin number of your car and get a new set. but it will cost you i'm sure. otherwise go to your local wal-mart and get some new ones copied.
yes. With your V.I.N. number any dealer can pull up your key number. with that number any lock smith can cut the keys.
