Can someone give me a little help on Identifying this 455 , Thanks
russell88
Florida
Need a Little Help to Identify this 455 , Thanks, I enclosed photos and Description.
First photo is back of Block with number 485428
Second photo is K107 ON Passenger Side
Third Photo is B158 Driver Side
Forth Photo is 394096 YC
Fifth Photo is B082 located back top of block by Dist.
thank you, any other information I can provide please let me know.
Block is late 1971 HO ( 455)
Date code is February 8, 1972
YC is either 325 HP 4bbl 1971 or 225 HP 4bbl 1972 ( yc is usually a 2 bolt block)
Doug in P.R.:cool:
Is there anyway I can find out what car it came from? And thanks for your help..
I think there is a typo above since YC was never a 71 455 HO, its the regular 455 and with a 72 date code it couldnt be 71. So a regular 455 in 72 could be almost anything, GTO, Firebird, Catalina.
http://www.wallaceracing.com/engine1.htm
Find the vin # on the block!
Passenger side lower front near the timing cover, 9 digits should start with a 2 and the third digit should be a letter or a " 1 " if it was a Canadian built car.
Doug in P.R.:cool:
You are probably correct Mel, ( Vin will tell the real year) but back in those days, they did all kind of crazy things . The block in question's casting number was used from 71 - 74 485428…
Blocks were cast way before the car was assembled so it could be a late 71 cast block date coded for a 72.
More likely it wasn't an HO block. Just bad info on the web.:rolleyes:
The Chevelle site tells the whole story on GM block casting that most people don't know about.
Ever read about the Lordstown plant problems in the early 70's?
Doug in P.R.:cool:
I am aware of a GM strike that occurred in 1969 delaying the introduction of 1970 models and resulting in certain cars being produced way past the normal end of year production. In my case my 69 Corvette wasnt made till November of 69 and has certain features that generally did not become available till 1970. I havent run across anything showing it's effect on Pontiac production.
