Center Brake Light Works....But Not The Main L&R Brake Lights....HELP?!
spini937
Hi everybody! So I'm at a loss here. I've changed the left & right brake light bulbs, and changed out the multi-function switch....but no luck still. Any ideas would be VERY appreciated as I'm an airline employee, and I really don't need the Airport Police pulling me over again :/ Thanks in advance for the help! :)
Since you didnt provide the year I cannt check the owners manual to see if there is a separate fuse for the main brake lights. Check the sockets with a voltmeter for current. If you have current at the sockets then you have to check the ground connections. Do they flash when you put the 4 way flasher switch on? Has the car been in a rear end accident?
