changing head gasket 2001 pontiac montana?
  • Thread starter Thread starter Michelle
what about changing the head gasket? what do you want to know?
have you tried a chemical sealant? if a minor leak there are sealants sold to address this problem. this will work half the time. if repair is needed it is quite difficult and may require a professional
What is it that you want to know about the head gasket. If you didn't run it to hot to warp the head ,they can replace the head gasket and it should be good to go.
