Check Oil & Low Coolant lights on
benkenobi
My "Check Oil" (not the red oil pressure light, but the orange "CHECK OIL" light) comes on when starting the car after it's been sitting for a while (overnight, sometimes 4-8 hours during the day), but doesn't come back on if I drive the car and restart it. As far as I can tell, my oil isn't low (which is what the light is for, right?) and when my oil IS low, the light behaves the same way.
Also, my low coolant light stays on all the time. I tried replacing the sensor with a junkyard pulled one and still no luck. If I wanted to test the sensor itself, would it be a resistance or continuity test? If it isn't the sensor, where else can I look?
Thanks!
