clutch problems with my WS6
  • Thread starter Thread starter Unregistered
U
Unregistered
when I race and run through 4 gears hard my clutch seems to stick and when i come to a stop i can shift back to first...i have to pump it a few times to loosen it up. this only happens when i drive it hard tho never from just driving normal. do i need to bleed the fluid lines?? any help would be great ..thanks
it is defiantly a hydrolic problem you have. If your car is pre 01 then you need to upgrade to the 01+ slave cylender. If you are 01-02 then bleed the system, and if it is dark then change out the fluid.
First thing to do is check the level of fluid in the resivore- it is on the driverside close to the firewall.
