Hi and thanks for the add. I have a 91 Sunbird that the top just stopped working. The relay is getting the signal from the switches but doesn't activate the pump. I jumped the pump and it works.
I've opened the relay and there are no broken conductors or burned contacts. The relay seems to be made of unobtainium and nobody has one. I was thinking of rewiring with a pair of cube relays but
the system swaps the ground conductor and i can't come up with a solution. Any help would be appreciated.
