02 Sunfire 2200 engine. NO thermostat in housing. Belt routing according to decal. W/P should be turning correctly. Coolant should come from bottom hose to radiator-thru rad-out to head.
Thermostat only fits in housing one way, with the pill toward engine-which means the hot water would come out the lower hose into the radiator.
But the coolant is flowing OUT of the head which would push the COOL water on the wrong side of the themostat.
Any help or ideas, wrong belt routing,(pump rotating wrong). thermostat doesn't go into housing it look like it belongs in?
Thanks, Les
Sorry 98 2.2L engine.
Thanks, Les
