Could these less work in my car
dppdaddyyo
there 120 watt led 12000 lumens, my main concern is the 120 watt will I need to put bigger fuses in? they def seem like they would be really bright, I'm currently running 35 watt hids that just are cutting it, I was looking at a set of 55 watt hid kit it was only 4500 lumens
fuses prevent your wiring from burning up so never put in large rating fuses. You should be using a relay and new wiring to feed your lights.
there 60 watts a peice it's says they should plug and play no mod required . it has its own ballast as well. idk can't hurt much to try it. seen some videos online of similar bulbs with 12k lumens they are super bright
60 watts is fine your original post said 120 watts
I just put these in last night man these suckerers are bright!!!!!!!! I was driving in pitch black with rain and could see clear as day. only thing is my adjustment scews are rusted and won't move so I may but new head light assemblys just so I can adjust and really bring the full potential of these bulbs.they don't project a blue hue it's a clear white. honestly being 12k lumens they may be illegal tho....
