crankcase hose
rob2421
There is a hose that goes from the air intake to the back of the engine that has come loose, any idea how it should be connected to the hole in the engine? It will not stay in
It's a 2006,17 is the correct one, the fitting is there but it seems to be too little for the hole
Should there be a fitting where the hole is from the engine?
can you post pictures?
I will post pics later, it is a 3.5
Gotta bring this back up. That line has come off of my 05 SV6 and can't see where it goes on the back of the engine. The black rubber fitting is still on hose.
Thanks.
have you looked at the valve cover for the other end
