Did I put my sway bar in right?
Dilsterboy
I have a 1972 lemans and im not sure if i put it in right. The is the order is put the linkage kit in. First you have the bolt then washer, spacer, control arm, spacer, washer, brass tube part, washer, spacer, sway bar, spacer, washer, nut. Thats the prder but i wish i could upload the pics. Im confused ive forgotten which way my sway bar goes in. With the flex or bent joint of the bar facing upward or downward idk!
You take the link bolt and place a washer on it followed by a rubber bushing. You then insert the bolt throught the bottom of the A arm. You then slide another rubber bushing followed by another washer on the bolt. You then slide the tube on followed by another washer and another rubber bushing. Insert the end through the bar and place a rubber bushing followed by a washer and the nuts. Sounds like you are saying the same thing but calling bushing a spacer. The link below has a different type of bar but you can see the arms of the bar go up.
What size bar did you install? Are you installing/changing the rear bar?
http://www.highperformancepontiac.com/features/hppp_0703_pontiac_firebird_fire_am/viewall.html
