difference between Trans Am hoods &...
  • Thread starter Thread starter ♡exes & ohs♡
♡exes & ohs♡
...Styles? i was wondering what the difference is between the hoods like the ram air & ws6. then also what's the difference between the regular trans am and the Ws6 trans am. and is the formula worse than both of those? I am going to get a trans am soon (hopefully) & i would like the must powerful but also the most good looking one i can get. any help or advice or whatever would be really helpfully. Oh and also, just wondering if there is a way to increase the fuel efficiency without loosing any of the power?
and is there a firehawk or something like that also? Does it look like the trans am & is it better or worse performance wise? sorry i have so many questions.
one last thing: which is the raised hood b/c i like that one better?
Basicly they are all the same car under the skin with little differences in the bodywork Hoods, ground effects, and wheels
but they all use the same drivetrains LT1 93-97 and LS1 98-02 with either a 4l60e or T-56, 6 speed trans and a small assortment of rear gear ratios ..
the WS6 package was just a apperance package and suspension (wheel, tire, sway bar, package) and there were some aftermarket (Firehawk packages) and the sort, but the standard Trans Am is the one with the bigger hood ..
as for economy just keep your foot out of it and they can get 20+ MPG
Good luck with your search.!
