SweetAztekMa'am!
- Dec 26, 2022
Hey, folks. Driver side seatback lever was stripped out, causing much frustration and inopportune stuckness of the seat position. Noticed the part is discontinued everywhere.
Husband macgyvered it, per the photos. Stick a screw through the side, basically, to jam and secure it so it stops spinning. Panel was a slight pain to remove to access the lever hardware, but you DO NOT need to remove the whole front seat per another forum on a different site advises. There's about 3 screws (front, back, and side of seat) to remove, unless some of them have already fallen out in the previous 20 years which was my luck. He did use a tap & die kit to make the hole and threads for the screw.
