94 2.0L manual 166K.
If I remove the battery cables and wait 15 minutes the car starts immeadiately runs rough a minute during learning curve, then runs great and you can go drive it stopping and starting all day.
After sitting overnight it will not start. No DTC codes. repeats 12 when flashed.
I have removed the two connectors and cleaned with electrical spray and applied a bit of contact enhancer and no change.
So, I'm pretty sure its the ECM. I am willing to replace it at this point.
However; I would like to know the thoughts of those here as far as where to order one from and any experiences involved.
I was thinking the GM website because of OEM and they offer a $90 core.
I want to stay away from aftermarket bc of things I've read, but I cant remember where they said to definitely not order from.
Do I need to have it flashed with VIN or does the PROM retain that information?
Thank you
Thank you
