Electrical issue
04aztek
So I got my 04 aztek cheap as sin like 500. Sometimes all the gauges and radio work fine so etimes no gauges or radio when engine is running. With the engine off, radio works and gaufes don't than after like 15 seconds or if i wiggle the key the radio goes off and coolant gauge registers than i start the car but still no radio and gauges what could be causeing this
Could be a bad ignition switch or a bad cluster or some other cause. Tests would have to be run when the problem occurs.
how does the BCM fit in with wiggling the key?
