smayfield
Hi... I just replaced the fuel injectors on my 2002 Aztek (258k miles). After re-assembling everything, the car barely runs, usually stalling out right away, occasionally revving pretty high if I tap on the gas... check engine light came on and I pulled 2 codes from it... P0108 (MAP/Barametric Pressure Circuit High Input) and P0453 (EVAP Emissions System Pressure Sensor Switch High)... I recently did a head gasket replacement and most of the evap related hoses are brand new... I swapped in a new MAP sensor, but no effect. Before the fuel injector swap, the engine actually ran fine (minus a miss on cylinder 4 and a fuel injector circuit open code, which I diagnosed down to an injector wasn't plugged in completely). After the FI replacement, that FI open circuit code went away, but now I have these 2 EVAP codes. Any though on what I might have put together incorrectly that would result in these two codes together? I'm assuming it's user error at this point.
