factory tires for 2002 sunfire se
bomoe1
Hey people, I have a 2002 sunfire 2 door se coupe and need new rubber. I am still running the factory steel wheels and would like to go a bit wider on the tires...factory spec is 195/65/15 and would like to go to a 205/60/15 . Anyone know if there are any problems with rubbing or any other problems going a bit bigger? Thanks in advance.
www.tirerack.com lists the 205/60/15 as an optional size for your car so I would assume you are good.
Thanks agn about the factory tire size
One more question, I see a couple of 2002 and 2001 grand prix and grand Am with nice aluminum factory wheels, most 16 inch, will they fit my 2002 sunfire se?
from what I see the Sunfire has a 100m bolt pattern and the other two cars have 115mm bolt pattern. Look for 16" wheels from a Sunfire GT
