Can't get proper alignment on the Front right wheel of my 1998 Trans Am Conv and I want to avoid just replacing parts until I get to the right one. Front tires are positioned as follows ( / \ ) .15degrees left .50degrees right) causing inside tire wear on rt wheel. all suspension parts are original and steering and handling are both good and tight with no play, There is no adjustment avail in the strut tower, although you would think there should be... Any thoughts?
