Is there a fuse for the fuel pump circuit? I found the relay in the fuse box, but cannot find a fuse. I have now power to the fuel pump, any suggestions?
I have a similar problem with my 92 Grand Prix 3.1 which is what brought me here. Engine runs fine off of starting fluid but gas isn't there to sustain it. You most likely do have a fuel pump fuse, mine does. You might want to look at the Autozone wiring diagrams for your year. Might even be the same as this one.
My biggest worry is that it'll turn out to be something in the "Engine Control Module" which may help decide what I do with the car (haven't priced one of those yet. Having found this thread, I'm headed out now to check the fuse and try and swap a module. Good thing about the modules is they're dirt cheap at AZ ($13).
