Hi ,
i have a 95' Sunfire , 2.2L , 4dr. Sedan . The issue i am having is the fuel pump is not turning on when you turn on the key . I have had the fuel pump out of the car and bench tested by my mechanic and the pump works fine . i have checked all the plug ins , fuses , and fuel pump relay , all seem to be in working order . I was told their was a way to bypass the pump from the relay and was wondering where i need to place the jumper wires . The Pins on the relay are numbered 1 through 5 . Any help would be greatly appreciated . I was also told that it might be a bad ECU ?.
Brian.
Brian.
