Gas Leak from Engine Under the Hood.
vovka2007
Great. My 05 Montana is starting to have issues. Once in parking lot i turned on a car and there was bun of Gasoline leaking from under the Hood. i turned off the car and it stopped. i Waited a little bit and then started the car again and everything was fine. It didn't happen again for a while, so i thought it was just once in a lifetime even. but then couple of days ago it did the same thing from the same spot. it seemed that its leaking from this spot. Could anyone tell me what it is? and how do deal with this issue.
considering that you have a fire danger, how come you havent taken it to the nearest repair shop to have it fixed?
Ditto, I wouldn't mess around eithe, all it would take is for that gas to hit a hot surface like the manifold and up in flames . I can't view the pic. Check the gas line connections from the fuel line.
how can i post pics here
Here is the pic, what is this part called
Fuel pressure regulator
Thats where the leak comes out from. Bad O-Ring or something?
I cant tell from the picture what part of the fuel pressure regulator the leak is coming from but the part is not serviceable, you replace the whole component.
