Hazard lights slightly illuminates before stalling
Not a 195?
I’m not sure all I know it was the lesser temp oof the two at auto zone. Them temp os staying stable now i did a 30 mile delivery today but the coolant level hasn’t dropped past the fill here line . And is it normal it only took a gal of coolant after i drained it and blew with air out of the cock valve to make sure it was completely empty
You earlier mentioned insufficient heat which would be the wrong thermostat.
So you think ioshould of went with the higher temp one? Also it started gettiing warm almost hot. But still I don’t know why the level doesn’t drop yet and only took 1 gal of coolant
You have engine temperature sensors that expect a minimum temperature to be achieved after a specific time. If not it will throw codes. Find out what you actually installed.
