yes put the weights back to stock, read the instructions for the kit it will show you what you need for a stock engine.
From what I remember you will never need the aftermarket weights even if they were correct, unless your running a roller cam roller lifters and many other engine modifications.
When you modify the engine where it is much faster reeving then perhaps you may want to look into this again one day.
